1 - 7 of 7 Posts
Anyone using this and have info or want to sell one?
Reasons for considering skidplate - I live off a gravel road and makes using the skidplate to lift bike easier...
if you have input or want to sell or recommend one maker over anothers?
witchdoctors has one and also a video on installing it.
i put one on my 12 XR that I got from HMD520. the holes did not line up so I had to bore them out so I could get the 4 bolts in. Not really a big deal but the part is rather pricing in my opinion so I would expect a little better quality. No experience on the one from Witchdoc but I would think most likely from an outside source since they look the same. Again, not bad-mouthing anyone just be aware!
RIDE SAFE!
RIDE SAFE!
Thanks for the info... How well does it work when using with bike on a MC lift? Any experience there?
Others have said it works well with the lift. Much easier. I have one I haven't put on yet. Too many other things with a higher priority right now.
I can tell you it's heavy. I doubt many would feel it being so low on the bike but it may effect gas mileage slightly.
it is heavy and works great with a lift or jack. being flat on the bottom makes it more stable while lifted......
I've got it mounted on mine, makes no differance on gas mileage. It took all of 30 mins to install with the help of my jack to get the holes lined up. It does help with the lifting of the bike however you will still find its best to remove the trunk before lifting.
1 - 7 of 7 Posts
