1 - 3 of 3 Posts
Has anyone cut the tab holding the vent inside the gas cap cover to index the gas cap? I believe moving the cap would facilitate easier fueling, especially from the left side or even 90 degrees to what comes stock...
The vent sticking up should hold in place - I don't know.
2 of the 5 bolts that appear to hold the cap assembly on are dummies and the holes are spaced in a way that won't let you rotate it. You can get a pop-style cap from Kewl Metal and if Ness got their venting problem fixed you can get caps from them too.
Great info Ammo, thanks. That's what forums are made for..
1 - 3 of 3 Posts
