1 - 13 of 13 Posts
I have a friend for whom I do his wrench work, he has a 2008 Vision and I am not familiar with how to change the fuel filter and can't find info or videos to help me. Anyone here done that and/or have links to info/vids?
BP, the Vision is completely different as it has 2 saddle tanks. I have changed the fuel filter in my XR, so that's no stranger to me, but the Vision sure is. I went into the parts pages and there is no mention of a fuel filter. What?
#1 take chrome bezel of gauges
#2 pull panel in front of seat
#3 remove dash panel SCREW in glove box Watch out
fuel pump on top of right hand tank.
#4 remove right hand top panel
#5 remove dash
#6 remove right hand mirror mount.
make sure you unhook battery
you can see from photo pump lift straight up
any help write me I can try to talk you threw it
RICZ
sebd Rylan at the vic shop a email and ask for tips or how to will be your best bet
Is the filter connected to the pump assembly somehow?
Ooops, sorry RICZ .... Subscribed and awaiting for GOOD info, we have 3 visions on the island so am very interested in HOW TOOOOO with pictures of course ??
So the vision has 2 tanks but capacity is the same .... Hmmm
TaPaTaLk for VIC forum
No filter on a vision fuel pump
Tell me the pump works will good fuel pressure say 49 psi.
if it has good pressure don't mess with the pump there is NO filter
His Vision is running OK - just thought with 40K miles, it might need a fuel filter change, if it had one. Thanks for letting me know it doesn't. Strange.
There's a filter, the fuel pick up at the bottom of the pump assembly has a flat section of filter media that the fuel is drawn through
(highlighted here on parts diagram) . I wouldn't touch it unless the pump is screaming.
[/URL][/IMG]
Discussion Starter #13
When viewing the parts illustrations, I suspected that thing as being a filter, but not user replaceable. Thanks for confirming that.
1 - 13 of 13 Posts
