1 - 3 of 3 Posts
Engine Light
I recently had issues with the engine light coming on after I started it. The problem was low voltage and in my case turned out to be a battery problem.
burt
The Diamond
As Burt said probably your battery. 9 times out of 10 that is the culprit. Also check and be sure all leads are tight to and from the battery.
1 - 3 of 3 Posts
