1 - 3 of 3 Posts
2013 8-ball under 6,000 miles. Check engine light comes on while in N or 1st while at idle at a stoplight. As soon as throttle is applied it goes away. Called the fealership, they said bring it in but I won't be able to for about 2 weeks, other than that they were useless. Attached is a pic of the code.
first thing to check on a vic is yr battery connections cos theres no lockwashers they can get a bit loose, clean, tighten and smear di-electric grease on em.
My Vegas throws red check engines sometimes and idles like ****, its the temp sensor on the front cylinder a white clip, try taking it off cleaning the contacts smearing with di-electric grease, may not fix it but certainly wont hurt.
someone here may no the error code I dont, my bike dont throw em up on the speedo, its gotta be plugged in .
The dealers and mechanics in Brisbane are great , no good to you though.
Good Luck
1 - 3 of 3 Posts
