1 - 2 of 2 Posts
Has anyone tried to change the black housing of the stock rear signal lights with the chrome housing that comes factory on the front forks?
So far I have swapped the lenses with the ones sold by Noemtz but now I want to do something more. I like the stock look with the clear lens, especially on the front. However, my machine is black and chrome and I think the chrome housing would like slick at the back. This would be a cheap mod as well as there are always used stock blinkers floating around.
Other than the plastic clamp on the front forks the front and rear look the same. I haven't started to pull anything apart yet. I thought I'd ask.
Let me know what you all think.
Thanks. Peace.
I believe swapping the shell will work....you just need to disconnect wires inside, swap out inner backing reflector....
Give it a try with your chrome fronts.
Thanks. Peace.
1 - 2 of 2 Posts
