1 - 10 of 10 Posts
Hey guys I was wondering what the diameter of our fork tubes are. 39mm or 41mm. I need to get a set of front blinkers for my vegas since I don't have any.
Conventional telescopic fork, 43 mm diameter, 5.1 in / 130 mm travel
I was looking at the clamps again and was thinking if the tubes are 43mm and the clamp is 43mm won't it be loose. So wouldn't a 41mm clamp fit tight on it.
That's not how it works, if the signals are 41mm signals that means they're made for 41mm forks. I just went through this with fork boots.
I was curious about the same thing.
You say the diameter is 43mm but on the victory website it says they are 46mm diameter. At least for a 2012.
SUSPENSION
Front Suspension Conventional telescopic fork, 46 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube, cast aluminum with constant-rate linkage, 3.65 in / 92.7 mm travel, air adjustable
SUSPENSION
2012 what model
1 - 10 of 10 Posts
