1 - 20 of 39 Posts
just purchased a used Cobra FI2000 from a member on this forum and looking forward to installing it. I have read alot on this forum, good and bad regarding this tuner so Im very anxious on how it will perform. My question is
Does anyone know where there may be an install video which relates to the CCT and is there anyway to tell if the internal adjustable "pots" have been adjusted. Being that this is a used unit, I want to make sure Im starting from factory settings. Also, if anyone has some tips or advice, Im open to all suggestions!
email
I would send an email off to Cobra. They ought to give you the factory settings. If not it is bad press for them when you comment on the forum that they would not help you with settings. A simple set of numbers out to be easy for them to email you back.
At makes sense, although I have heard and read that Cobra will only answer questions and provide information once a sales receipt has been provided. Whether or not this is true, I'm not really sure. But since I bought this used I do not have a sales receipt,but it's definitely worth a try
Follow the instructions, except do not connect the stock O² sensors - leave them disconnected. Don't change the controller's dial (inside the controller) unless you have to adjust it later, after you ride it for at least 50 miles. If you have any trouble or specific questions, just ask.
I've been waiting to a do a write up on the Cobra Fi2000 until I had it all worked out and the high flow air filter installed.
I feel like the Cobra is a decent turner and does increase performance but its not quite fully "developed" for the Victory application. Cobra's CS and that asshat Andre' in tech support aren't worth a crap, so save yourself the trouble.
First things first, open the unit(start where the wires come out) with a small flat screwdriver, look for the "pot" the factory puts a dot on it at the "7oc" position, if the dial line is pointed at the dot then it is still at the factory setting.
Installation is pretty straight forward, getting at the injectors is tight and getting at the front O2 sensor is a total pain. Do yourself a favor and loosen the three bolts on left side of the chin fairing, it'll give you a lot more room to work and get at the O2 sensor clip. Zip tie the clip up in an easier access position, you may need to get at it again.
I'll make this as short as possible. Installed my Cobra Fi2000 per instructions on a stock bike. I got minor performance changes. But more concerning was that after ~300mi I started getting "lean condition" engine error codes and random engine stalls(not cool while riding...). After some research I learned about the internal pot. I set it to "9oc" but had the same problems. I ended up disconnecting the Cobra from the O2 sensors and reconnecting the OEM lines. After doing this the bike came to life. I felt more responsiveness and now that I've opened up my exhaust its taken another step up.
I learned running with the Cobra Fi2000 connected to the injectors(and ground) and its O2 sensors disconnected, while having the OEM O2 sensors plugged in will allow the Cobra Fi2000 to control fueling in throttle on conditions and the bike's ECM will handle steady state and throttle off fuel management. I can say its performing very well in this configuration, I get no error codes, stalling, backfires or decel popping.
I have tried to reconnect the Cobra's O2 sensors but this causes the engine to have an occasional random engine stall between shifts which is friggin' scary and dangerous when it happens with no noticeable performance gain. So I'm using it in the configuration that works and am happy with the results.
I'm still trying to find someone that is actually interested in dealing with what's going with these tuners but so far dealing with Cobra is netting zero results...
Hey markaas...just noticed you're in CT. I probably could help you out in person. Or if you need to put eyeballs on my setup, make time to show you.
lmk
Hey thanks so much for that usefull info. Andi just may take you up on your offer. What part of CT are you from, im in danielson. As far as disconnecting o2 sensors, do you mean plug them into the tuner only and then leave disconnected? Not sure i fully understand what you mean, im new to this tuner stuff!!
How many pots are inside the unit? Looks like i see only 1, is that correct?
Only one "pot", its hard to miss and hard to mistake for anything else.
What I and CrossRoads mean about the O2 sensors is; do not connect the lines that come off the Cobra for the O2 sensors to the bike's lines. Just leave them free. Leave the factory O2 sensors connected.
I'm in Bristol, CT.
Discussion Starter #13
Its the cobra power profi2000, part # 1053At. Thanks for the clarification on the o2 sensors!
Sounds like Pain is the man for the job. I hope you two can get together and he makes it all work great. Great folks on here,
Yes pain has the right Idea. Leave the factory O2's connected as they are. Coil up the Cobra's O2 harness and tuck it neatly behind the side cover. In order to install the injector connectors you will have to have knowledge of removing the gas tank. (see Witch doctors how to video for info). You will need instruction also on CAREFULLY removing the injector connections. Once you have the Cobra injector connections done and the bike back together go for a ride. Do not adjust the little pot under the Cobra cover yet. Ride for at least 50 miles.
So when is it time to mess with the little adjusting pot in the tuner? That will depend on how your bike runs after 50 miles. Take it one step at a time. If you feel the bike is not running properly after the above instruction then your next step would be to adjust the tuner dial to the 10 o'clock position.
On my setup(PowrPro) the pot is adjusted to 9oc. I've left it there since the first adjustment attempt.
That said, I don't know how much good changing it actually does with the Cobra's O2 sensors disconnected.....I'm told that the "pot" controls steady state fuel, which with disconnected sensors is being handled be the bike's ECM.
markaas...I'm off today(Wed), back to work tomorrow, off the 4th, then leaving on the 5th through the 13th for a family vaca.(tough schedule, I know ;) )
I probably won't be on-line much during vaca. good luck. Hit me up before I leave if you want to see the setup.
Discussion Starter #17
paiN, I think Im gonna try and tackle this project this weekend. Ive done some reading and watch some videos and I think I can handle (I hope so anyway). I appreciate you advise. If I run into any issues, I know I can look to this forum for help. Everyone is always great! I let you know how it goes.
Thanks again
Discussion Starter #18
So I finally got the cobra FI2000 installed and completed. I only have taken it for a short 5 mile ride so far, but immediately noticed that if the bike is at idle for a few minutes and I crack the throttle there is a loud pop, almost like a back fire. And 2, at idle again there is a noticeable almost like sucking or scrapping type noise that I can hear. Seems to go away if I give it gas (although may be not hearing with the engine reving) I installed per the instructions and although a few recommended that I leave the o2 sensors disconnected I did hook them up as I figured I could always disconnect them. When installing, I did remove the rubber strip from the air box and wondering if that's what I may be hearing. Does anyone have any thoughts on these 2 concerns?
Disconnect your O2's and then try it again.
The sucking sound is the vacuum leak. My truck does it too if I take the air cleaner off.
Wow, we could almost have a CT Cobra rally lol
Sent from Motorcycle.com App
1 - 20 of 39 Posts
