1 - 14 of 14 Posts
I want to install fog lights /LED auxiliary lights on my vegas... what wire would i connect them too inside the headlight?
I connected them to that very small light-bulb wires inside the head light ....
Andre using TaPaTaLk
ok, they go on when your bike is on...
On my jackpot i just put another switch in between
On my CCT i connected them to my High beam .... Low beam is HID but high beam is stock bulb,
so that is how i did both bikes different ....
Thank you... awesome..
I approach fog/ driving lights on bikes like automakers do on cars: they're on with the low beams or on by themselves. Personally, I'd have them on with both high and low beams, with a separate switch. That way the electrical system isn't taxed so heavily upon start up.
have you encountered any issues with hooking them up to the high beam? i spliced it into the high beam bulb and when i turn on the high beam the fog lights come on....
That's how I have mine set up.
With LED the Amperes are so small .... The fuse did not burn yet
And on the jackpot & CCT i always run these HIGH BEAMS
Believe the 'off with high beams' set up for cars is primarily due to the laws that require it in most States.
The set I mounted came with a harness that connected directly to the headlight harness. It is set up so the road/fog lights are on all the time but increase/decrease with the High/Low switch for the head light. There is also a separate switch that turns them off. This is a great set up that provides better light all of the time without irritating or disturbing oncoming traffic.
As for not taxing the electrical system, an LED's draw is so low I doubt there is a potential for trouble.
Well put, sir. On all accounts. And as far as taxing the system, I am going off the experience of others. My father in law has a bored out Suzuki marauder that wouldn't start if the headlight was on, unless he bump started it. His problem was the starter wouldn't get enough juice to move. He put a toggle switch on his headlight and solved that issue.
I still like the idea of having nothing extra draining the battery while trying to start whatever I may be starting. Be it lights, HVAC controls, fans, whatever. I'm a nerd like that.:nerd
ScabbyDoo what kit do you have. It sounds like a nice kit with easy install. I like the idea of the lights being on with both the high and low beams. The more lights the better I am seen. Thanks. MikeR
1 - 14 of 14 Posts
