1 - 2 of 2 Posts
Fenders, wheels, will all swap between a C & SC. If you want the 54mm forks & dual discs in front you'll need a new triple tree. If you want dual discs & stay with the stock 50mm C forks you can use one from a 99 with the disc on the right fork and a later model fork tube when they switched over to the other side.
1 - 2 of 2 Posts
