1 - 20 of 21 Posts
I'm not feeling good ..I've been fighting something off all day, I'm going to lay-low :( so this is as far as its going tonight.
This seat is actually a 2nd seat with a 3rd en-route.... Apparently with all Corbin's seat making experience they still don't know how to pack correctly. Luckily for me I bought it through an e-bay distributor in NH....the most excellent Freedom Cycle, this store has completely bent over backwards to take care of me, with special thanks to Aaron. The pointy ends by the side covers are getting damaged on the way from Corbin. The 1st one was badly torn up, on this one the damage isn't so bad and not visible when its on the bike. Freedom Cycle is letting me use the seat until the 3rd replacement comes in(2-3 more weeks) and is paying for return shipping back to them for this seat(if the 3rd one is not damaged...)
Hopefully, I'll be back up to speed tomorrow and I can get this on the bike and try it out. It feels great(plus it has that new seat smell :D) Its definitely firm, but not like a board or anything....there seems to be a layer of memory foam over the base foam.
Seat
Is it more comfortable than stock seat and worth the extra $ $ ? ?
Olddad, I can't speak to the Corbin seat but I can certainly speak to Ultimate seats. A couple years ago while I was in Daytona I went to both stores, Corbin and Ultimate. The Corbin store did not have any display model or any thing similar to the Vic cross country seat for me to look at or sit on. The Ultimate store had everything on display. I purchased the Ultimate with the drivers backrest. With custom stitching and shipping it came to just under a grand. Big money. The seat was delivered about 3 weeks later when I was back home in NY. The seat rubbed on the saddlebag lids and rear fender. In fact, I had to push the seat padding in to close the bag lids. The seat is very comfortable and makes long rides a breeze. The seat eventually rubbed through the clear coat on the bag lids. I called Ultimate and explained the problem. They said that the Vic bikes are not consistent from one to the other but would modify the seat if I sent it back. I taped up the areas that were problematic and spent $60 on return shipping. The seat came back fine, but now, almost 2 years later the seat is compressing and once again rubbing on the bag lids. I recently purchased a sheep skin to put over the seat, it's the best $100 I've ever spent, cooler in the heat and warmer in the cold. You might want to try a sheep skin before dropping a boat load of money on a custom seat.
@kodiakwood2 I did try out an Ultimate Seat a year or two ago and it wasn't at all for me....That "couch cushion" softness made me feel disconnected from the bike and as I sunk into it the seat started to become "pinchy" on my clothes, its forward portion was to wide, I didn't like the feel when I was stopped and that soft foam got very hot, it seemed to hold in heat. I ended up sending it back.
@olddad64 I haven't had a stock seat for a long time. I've been running with a Drag Specialties Low-Profile Touring Seat This seat has worked great for me, its firm with great support, we have done many miles together. Comparing the DS to stock, yes, it was much more comfortable. The stock seat wasn't bad, but like most stockers the foam and support give up after awhile of riding, the DS seat does not do that, the support lasts until I get off the bike.
I know... If I like the DS so much why did I buy a Corbin? I've always wanted the Corbin Dual Tour for my XC, I think it looks amazing on the bike but more than that from all I've read it is the ultimate in firm seat-ness ;) and I believe the Corbin Dual Tour will sit me back a bit compared to the DS. Aaron the guy I was dealing with at Freedom Cycle said he's been using Corbins forever and won't even buy a distance motorcycle if he can't get a Corbin for it.
edit: I ended up popping a fever, which finally broke around 4am, at which point I finally got some sleep. I'm a little beat up from whatever zingged me, but if I'm feeling MUCH better, I'm going to chill for a few hours, if I still feel okay I'll switch seats
I had a Corbin on my 850 Beemer, although that was 20 years(!) ago. I found it too firm, and have since read -- on forums on several different bikes that I've owned -- that a lot of folks feel that way. So it'll be interesting to see if you like the new seat, after a full day's ride -- report back, PaiN.
Weird, that I've used BeadRider beads on my last three bikes. They're certainly harder than any seat material, but my ass doesn't complain. Must be the way they move around, or something. Go figure.
I'm sure Corbin has improved their technology over the years. True some of the older Corbins I've sat on felt extremely hard, maybe they were broken in to someone else's butt or it was an older type of foam. Anyway, I bought this seat for the firm support, I don't want a seat I'm squashing into.
Plus, you're a tough guy, anyway.
I had a solo Corbin on all my electric glides and road glide. Yes it was hard and by butt fit just fine. On many trips of all day riding my butt would hurt after about 4 hours. With in 5 or 10 minuets the hurt was all gone. I talked a upholster guy and he said a soft seat you'll be always shifting around but a hard seat you'll move around very little. I look at them 10 speed bicycle riders with there hard leather seat and they all say once its broke in you'll love it
That Corbin is certainly an attractive seat ....
The Corbin is installed and I'm liking it already :D Initial firmness feels a little bit tighter than the DS seat but not a drastic difference. What I do feel is back from the bars about a 1/2" and really cupped in nice wider pocket, that's immediately neutral, no shifting around to get positioned. I can also feel the ribbing, which means air flow and no heat build up. The Corbin leather has some texture and seems to hold better than the DS, I'm wearing stretchy sweat pants and didn't really slip around at all. It looks great on the bike, like I've said before, the Dual Tour is the best looking seat for our X bikes. There's more real-estate on the Corbin vs. the DS(see the pic below) I was a little nervous that it might be rubbing something but it doesn't. One last thingie....the Corbin is at least twice as heavy as the DS seat, most of that has got to be from super stiff fiber pan Corbin uses.
I feel much better today but not 100%, I hardly slept overnight......I should probably cool it today so I don't relapse.
Corbin seat
Corbin seat looks good there PaiN....I may try one $ ?
Unheated, no backrest or accessories they go for ~$670 shipped then it on up in $$$ from there....Sometimes you just have to eat it to get what you want ;)
Since Corbin builds each seat to order. They do have a free customizing service which is done on an interactive portion of their site. On any order the seat can be built with any number or colors and materials.
Corbin Motorcycle Seats & Accessories | Victory Motorcycles | 800-538-7035
customizer:
Damn, that Corbin seat sure looks good on the bike
That seat looks awesome! My biggest issue with the DS seat was that it didn't have the cupping so to speak like stock and it rolled my ass forward awkwardly and that was causing me middle back pain. I did like the firm support compared to stock but it just wasn't the right shape for me. Hopefully I'll get to check this Corbin out first hand very soon.
Sent from my Pixel XL using Tapatalk
Discussion Starter #16
I know exactly what you're talking about with the DS seat but it never was an issue for me. I'd just have to keep pushing back into position....That's what I was referring to when I wrote "really cupped in nice wider pocket, that's immediately neutral" after I sat in the Corbin for the first time yesterday.
If we can make that ride Wednesday, you can try it out. If you love it.....who knows maybe I could work out a deal with Aaron at Freedom Cycle to get this one at good discount... The damage is insignificant and can't be seen when its on the bike.
Discussion Starter #17
Sorry guys I haven't been able to get the bike out to try out my new stuff...cuz' I'm still sick :mad: I was feeling better yesterday morning, got called into work to do one test, then I did a few errands and vacuumed the pool to get it ready to close.....It was probably too much, by evening I had 101+ fever again....I called out today and slept until 9 ..it was much needed. I'm going to do NOTHING today no matter how much better I feel, hopefully I can beat this thing.
Discussion Starter #18 (Edited)
I hadn't said much about this seat lately.... As is usually the case with me, there is "more to the story" :rolleyes:
I had been riding it around locally and enjoying the seat. @roboots21 came down for a poker run one Saturday and ended up falling for the Corbin. So I let him try it out for the rest of the weekend. Roboots really liked it and to make a long story short, we worked out a deal where he would purchase the slightly damaged seat from Freedom Cycle at a discount once the 3rd replacement seat came in for me. This was going to work out well for all parties involved.
The distributor was expecting a 2-3 week turn around, but time dragged on and I started to feel like I was "breaking-in" roboot's seat. I decided to deliver the seat to him early. Finally after almost 6 weeks the replacement seat came in and it was undamaged as well. At this point roboots paid the the agreed price to Freedom Cycle and they shipped out the 3rd seat. Roboots and I live more than 2 hours apart, for reasons I don't want to get into Freedom Cycle shipped the seat to his address instead of to mine :mad: I had been patient through this whole thing, but this time I pulled a "nutty" on the phone with Freedom Cycle(as good as they've been they deserved it this time....). Anyway, they paid for a pick-up and ship from roboot's to my house and I finally got the seat late Thursday night.
Its the same except no damage on the tips and this one has the logo in black stitch....I like it.
Going out to put in on and get some miles in this weekend. The weather is still holding here in the North East and we are getting some good riding in.
If you and your ass are happy, we're all happy.
Ken and I did some riding just this past week in the Catskills -- 23A, etc., and a bunch of Greene County backroads neither of us had ever been on, and lunch in Woodstock. Yep, still the occasional nice day.
Enjoy your seat!
The Corbin (#2) definitely has found a good home!!
1 - 20 of 21 Posts
