1 - 12 of 12 Posts
over on vog a guy said at 70 mph he heard a bad sound. 51K on his tour model. You can imagine how many guys said it was cause the oil. Amsoil 20/40. None of the guys though it could of been the bearing cage or a bearing itself. One of them even said he talk to the top 4 tuners and they said Amsoil. I thin he is working for CNN
Discussion Starter #2
Of coarse he doesn't want to spend the $7 grand to fix it but will a used motor be any better
Be cheaper to buy a another low mileage XC and keep his busted one for future parts!
Reactions: FoFo
Quote
Unquote
Incorrect, only 1 guy said it was the cause of the oil ...
Quote
Unquote
Incorrect, he said according to 2 vic engine builders ..... He is just trying to look important ... No vic guru would make statements against a billion $ company ....
This guy it's tradition to bash fellow forum members ..... Someone blows up a tranny and gets bashed for oil .... Crazy mate, just weird and wrong ....
Andre using TaPaTaLk
Reactions: Chuckz71
Those pictures are awful. Is this a bearing failure or did something else failed that took the bearing out? Does that bearing ride in the oil all the time. What a nightmare for the owner. So sad.
I'm guessing the number of trouble free Victory's with well over 100K, 200K or even 300K miles is larger than the total number of bikes that lost the trans circlip or this bearing. Still, it makes me pause a bit knowing the brand is dead and my extended warranty is up in 3 weeks.
I agree with the posts above. Buy a new to you used Victory and part out the entire 'broken' motorcycle to recoup (some of) the cost. That's likely what I'd do anyway.
Reactions: BP6666VR
Is that what The Vic Shop quote is to fix it?
I'd go on ebay and find a good used low mile engine from a wrecked bike for $1,500-$2,000 and swap out engines then take my time fixing the first one on my work bench. Even if I ended up taking it apart then deciding it wasn't worth fixing; I'd still get the education factor from doing it.
It really sucks this $8 part caused all this trouble though. Had to be heart wrenching when he saw those bearings in there like that. Damn shame. I don't believe it was the oil either; especially Amsoil.
A deal like this is hard to hear about. But none of us know any of the particulars. Was the oil and filter changed on time? Was a "good oil" used or bargain basement type? Did he run it hard or normal? I have seen more than a couple bearing failures that were just bad luck. Part manufactured with a defect or something. Sucks for the guy either way.
Over on the vog there's a thread about it. He used Amsoil and changed it regularly. There are some who believe Amsoil is so slippery that it causes bearings to slide rather than roll. I find that hard to believe.
I think you're right; just bad luck. A certain number of anything mechanical will fail prematurely due to some weak link. In this engine it was this bearing.
If Amsoil is too slippery , why on Lloyds website he talks about "royal purple" oil .... isn't that even more high end oil so more slippery than vic or Amsoil ? Soooooo how van a slippery oil fail a bearing ? I call BS .... Hi hi
It is just bad luck .... For sample : If the bearing is SKF than there is a good chance they are made in China or Malaysia ....
This was posted from the lloyds website ....
Quote
From LLyodz............
This should have been the first thing I ever posted as it’s the MOST played out question on the web.
I get asked this ALL the*time. Which oil do I recommend in a Victory? My answer is Victory 20w40 oil! I don’t care about your oil analysts, I don’t care to hear your primary sounds quieter, I don’t care to hear the other oil you use is cheaper, I don’t care to hear any other comment you have about another*oil. Cause and effect, you may have caused one thing to “get better” but you just affected another to get worse. I see HUNDREDS of torn apart motors every year, I can with a great deal of accuracy tell which oil was in that motor. It’s not a super power I possess; certain oils leave characteristic stains, marking, smell and wear in different areas of the motor. I’m by all means not experienced in all oils in these bikes but there are the top 4 used that I’m experienced with.
Now I will also say, I’m not suggestion Victory oil is by far the best oil in the world for these bikes. I am saying, with the ones that are typically used Victory oil lends itself to be the*superior oil for wear and parts protection that provides a manageable and stable temperatures.
One issue raised is this, if*there is better oil, let’s say Royal Purple. It’s oil I’ve wanted to try for years. It would take me an unknown amount of years gathering information to sit down and recommend another brand. Conclusions can’t be made on 1 engine, that’s bit me in the ass before.
So what’s my ending statement?
If you have the ability to buy Victory oil, IMO there’s no reason to*open the top on another brand
I would chalk it up to bad luck, probably poor handling of the bearing or poor assembly. I haven't seen many pictures or many complaints of this on the internet.
It doesn't take much to ruin a bearing pre install, during install or after install. We tend to take them for granted but they are incredibly fragile if you want them to last in service.
Unwrap it set it on the bench , push it off the bench and let it drop to the concrete floor and it's life is significantly shortened.
At that point you throw it away if you know to.
It doesn't look damaged when you pick it up and in most installations it will run for a while, like this one did. But it's place is in the trash can because it is going to die prematurely. If it is heavily loaded prematurely is not very long.
Accidents like dropping a bearing happen. When they get installed afterwards instead of thrown away you have problems like this. It's just as easy to kill one with a single strike of a hammer. Good training goes a long ways Lack of training or lack of caring causes a lot of machinery to have a very short life.
Correct on all accounts @Joe
Offshore we have many problems with bearings ... Salt & concrete & drill mud, it is always something ...
1 - 12 of 12 Posts
