Must've been when I had the bike up in the air this morning to undo the front axle, discovered I need a different axle....but then I went for a ride.
Did about a 40 mile ride then almost home the red check engine light comes on.
I stopped bike checked engine and it was still there:smile
So I fired up didn't get far and it came on again, I kept riding to home.
Then I checked battery connections, separated cleaned and tightened, check battery earth to engine was intact.
Checked oil even though oil light wasn't on.
Separated the smaller connection under the bike cleaned pins, dielectric grease on socket seals and back together.
Went for a test ride, by now starting to get dark and I noticed my headlight going out when I revved the bike up and red check engine coming on at same time.
Back home to workshop separated headlight shell.
I've got Crossroads VictoryHID system so one by one I separated each connection cleaned with spray carby cleaner the dielectric greased the seal and replaced.
Did all the headlight connections.
Test ride and light went out as I got onto the road.
Came back pulled rhs switchblock apart sprayed carby cleaner though killswitch and starter switch.
Oiled throttle cables while I was in there.
Reassembled and test ride light goes out soon as revs get to aground 2000rpm....vibes or power surge dunno???
So I got a bike I can't ride at night and it's night.
Haven't stopped to eat all day so gonna eat then go back inside headlight and separate clean and grease every Junction.
Electrical problems give me the shits!
Moreso when I probably caused it somehow!
