1 - 13 of 13 Posts
For those of you that have installed the CB/Int system, or use a J&M CB 2003 on your cross country, where do you mount the headset cords and rubber sockets for the rider and passenger?
Thanks
Thanks
I attached the rider's headset connector to the left handlebar with zip ties. I have yet to find a place to secure the one for the passenger. Note the lifts under the CB unit. I did that so that the PTT lever will clear the switch pod. They are aluminum spacers I got at my local ACE hardware, along with longer screws. J&M didn't offer a longer bracket, so that was the cure.
I have(Victory CB) my plug in gust above the back cylinder,(where the instructions tell you to put it) I ran the passenger plug under the seat and threw the hole in the seat. thumb up
What I like about having the connector on the handlebar is I can see it when on the bike and can use two hands to connect and disconnect to take the strain off the wires. It's also a direct reach from the connection to my helmet and the cord does not touch the tank. Normally, the passenger's connection is mounted somewhere on the left side of the pasenger seat. She passes the cord behind her and connects before mounting. That way, after she mounts, the entire cord is to her left, as is the connection on her helmet.
Thanks guys for the info. I have the J&M CB, but havent hooked it up yet. I will try it both ways to see which might be better.
RICZ
Where did you find the handlebar clamp that your J&M bracket is attached to? I have the JMCB2003 from my Honda Sabre, but spoke with J&M and they said they don't make a bracket for the Victory XC. I looked at the one that they say fits "MOST Victory Cruisers", but it appears that the bends won't work for the XC to lift it over the controls.
RICZ
ACE Hardware provided the aluminum spacers and longer screws so the PTT lever will clear the control pod. My bracket has no bends - straight as can be, but it was made for a Honda. Which one, I don't recall.
Jmcb
I appreciate the info for the spacers and bolts, but I was wondering specifically about the chrome handlebar clamp that the bracket attached to...
I found the spacers and bolts at Home Depot, along with a U-bolt and lock-nuts. I ordered the handlebar clamp from a Colorado Victory dealer which appears to be a RAM product and can also be ordered with the ball-mount.
The 1/2" spacers worked perfectly.
I did have to adapt a piece of metal with which to mount the CB antenna and it lines up nearly perfectly with the radio antenna on the opposite side.
Good tools, ingenuity and a nearby hardware store will generally get the job done. cheers
Has anyone thought about mounting a standard cb between the handlebars of the motorcycle? Other than waterproofing would there be any down falls to this idea. I know the cost would be a lot cheaper, like $150 dollars vs. $1400 dollars.
I went a different way than the J&M
Sena SMH10B helmet Bluetooth $157.46
Sena SR10 Bluetooth adapter - $149.25
Midland 75-822 portable CB radio $79.00
The helmet Bluetooth has two loose speaker that you can mount in a Full Face or 3/4 helmet but doesn't work too well for a half helmet. They sell the SPH-10 Bluetooth headset that goes over the ears like a regular headset but that was $187.46 as well. Of course if you only wear a half helmet or even no helmet than this will work for you.
Instead I got another clamp kit that has a connector in the back to plug in any headset including earbuds. Sena SMH-10 Helmet Clamp Kit - For Earbuds $29.96
To connect the SR10 to the radio you will also need a $14.96 Sena SR10 2-Way Radio Connector Cable. If you use the Midland radio I suggest you get the ICOM adapter that way the cord is out of the way. If you get the Midland adapter the cord goes right beside the radio switches on top making them hard to use.
You can use the Midland radio with a wired headset if you don't want the Bluetooth option and stay below $150.
I realize that I came close to the J&M cost of $500 but there are also several other advantages as well.
1. It's wireless.
2. You can connect other Bluetooth enabled devices (like a GPS or cell phone). The SR10 also has two AUX ports so you can connect non-Bluetooth devices as well.
3. You can easily update the radio to FMS/GRMS by replacing just the radio.
For those who don't know, the FMS/GRMS has better range and clarity than a CB. Unfortunately there are about 8 riders in our group that have CBs and they weren't too keen on scraping their "tried and true" communication system for "the new guy"
Just thought I'd pass on some gouge that might help someone else looking for a similar setup. BTW, I have no ties with Revzilla, they are just where I happened to order everything except the radio
__________________
You guys running the J&M radio, I am have fits with engine noise. Squelch is turned up to max just to keep the static at bay.
I tied in the Noise filter supplied, tried straight from the battery and the aux headlight wiring.
Bike off I can back the squelch off some, bike running it has to be almost maxed out.
I have been fusting with this now for weeks and several call to J&M. No joy.
Gave up and ordered the OEM equipment from Kate
1 - 13 of 13 Posts
