1 - 6 of 6 Posts
Hey guys, is cruise control a simple plug in on my 2011 Vegas 8ball or do I need to run switches from clutch and brake? Also does the switch housing come in black?
Just to note... throttle locks are not "the same" as cruise control. If you go up/down a hill, speed will certainly change.
To the OP, I'd call the dealer and see what all is included with the system. I've considered this myself.
mounts on the bar fed down the bar under tank to the fuse box. That is where the power for the module is. I can not find it in the manual so it must come with instructions.. clutch brake switches are already in the system so it just plugs in. One guy in Canada had problems with his early in the year, you have to do a search to find it.
thanks Gibson i just took along ride and wished i had cruise control
1 - 6 of 6 Posts
