1 - 4 of 4 Posts
What size crush washer do I need for the top brake line on my front brakes? I am getting a super small leak and don't want to try and together it any more.
6 7556028 WASHER,BANJO,COPPER 4 Usage
6 7556028 WASHER,BANJO,COPPER v92.jpg this is from Victory web site. 7556028 is the part number.. There is 4 washers on the line with the same part number..
1 5131657 LEVER-HAND,FRONT BRAKE 1 Usage
2 2050079 M.CYL ASM,F.BRAKE,14MM 1 Usage
3 2201215 KIT,HDWE,FRT.M/C LEVER (Incl. Pin and Nut) 1 Usage
4 2201216 KIT,HDWE,FRT.M/C CAP (See Footnote) 1 Usage
5 2201182 KIT,HDWE,FRT.M/C SIGHT (Incl. O-Ring, Sight and Clip) 1 Usage
7 1930848 BOLT,BRAKE,BANJO,SPCL 2 Usage
8 1930871 HOSE,F.BRAKE,(CRUISER) 1 Usage
9 7517406 SCREW 1 Usage
10 2201173 KIT,BLEEDER SCREW,BOOT (See Footnote) 1 Usage
11 7517419 SCREW,SOCHD,M10X25 2 Usage
12 2201176 KIT,PINS,CLIPS,SPRING,FRONT 2 Usage
13 1930850 CALIPER ASM,FR,4 PISTON 1 Usage
14 2201170 KIT,BRAKE PAD,FRONT (2 Per) 1 Usage
15 4110242 SW,STOP,MICRO,FRONT 1 Usage
16 2201217 KIT,HDWE,FRT.M/C CLAMP (Incl. Clamp and Screws) 1 Usage
17 2201218 KIT,HDWE,FRT.M/C PUSHROD Substituted by 2050079 (Incl. Pushrod and Boot)
If your dealer has none take old one and go to honda show or kawie
and if the don't try h-d
am guessing 10mm
1 - 4 of 4 Posts
