1 - 5 of 5 Posts
folks ive seen some bad comits about freedom in cumming ga, checked and saw more bad reports on kennesaw ga, this makes me think about something.
when i bought my xct out of crate & after prep, i went over with sales guy, i started and went for ride the red engine light came on for a very short time and went off, i was told that it was normul when you start up its preshure build up. it only happens during start up then never. is this bull or what,
Do you jump on and ride or do you let it warm up the back cylinder first? Oil check every day on a new motor, I would document the check of the oil and the red light when it comes on. Are you accelerating hard when it comes on? Are you following the proper guide lines of breaking in your new motor? These are things on a warranty issues when they arise. If the dealer goes under or you take it some where else to get it looked at. I would log every thing..
when you start up it comes on for a few, goes off comes on for a short, then gos of and stays off. when you ride after warmed up never comes on, only after siting 4 to 6 hours. and yes i let warm up and breake in correct.
thanks
I have over 12000 on my 11 XR and have started it 100's of times. The lights in the guages come on when I turn on the ignition then go off when I start it. None of them stay on so yours sounds a little wonky. I would make sure the oil is at the right level; too low and the light will come on but if it's anything like my V-Star the light may also come on if it's too high.
Agreed. Check oil level first. If ok, consider an oil change using standard vic oil- it's possible the dealer put the wrong weight in.
How long have you had the bike and whats the mileage?
1 - 5 of 5 Posts
