1 - 5 of 5 Posts
Here are my fuel tables, am trying to get autotune to dial things in, but running just terrible at about 2600-3000 rpm. Any knowledgeable suggestions Thanks!
Discussion Starter #2
Added trims and ignition tables
With what little experience I have on it, those number look way out of where they ought to be. Then again, I don't have a cam and a big bore. I'm thinking if your map is known to be good, zero out the fuel tables and trims. The AT will figure the rest out.
Replaced exhaust gaskets and zero'd out all my tables.
I then contacted DynoJet and they tuned it over the phone. Bike runs GREAT!
Now, I just need to get a better set of tires that will put the power down bettercheers
Turns out the AutoTune Module was bad, took it off as a suggestion by Rylan and walah, no problems! Sent it in for replacement.
1 - 5 of 5 Posts
