1 - 2 of 2 Posts
dark_controller wrote
>So i was watching a video on swapping a freedom 92 with the pre-freedom 92, and in the video they said that the speed sensor on the original 92's was in the block and the newer ones read off the front pulley? Is this true? Can anybody give me the lowdown on this?<
+In this first image you can see the speed sensor mounted in the engine case just forward of the ECM box/heat shield and just behind the uppermost section of the drive sprocket cover.
http://www.roadkillonline.net/imagedb_images/35_3676.jpg
and just below the bend in the rear exhaust pipe in this image
http://www.roadkillonline.net/imagedb_images/35_492.JPG
When it's replaced, you get this (minus my oily mess)
http://www.roadkillonline.net/imagedb_images/35_6158.JPG
http://www.roadkillonline.net/imagedb_images/35_6159.JPG
http://www.roadkillonline.net/imagedb_images/35_9802.JPG (original in-place with wire snippage)
http://www.roadkillonline.net/imagedb_images/35_9803.JPG (replacement sensor at sprocket)
Ride on.
Roadkill
1 - 2 of 2 Posts
