1 - 8 of 8 Posts
I've done some searching but nothing has popped up. Wondering if anyone knew a thread with a video or with pictures showing how to debaffle the exhaust on a cross country
Oklahoma City. Mine are already done on my bike I had the dealer do it before I bought it. Got a buddy wanting to do his
Are you referring to sending a 1-1/8" hole saw up the pipe?
http://www.victoryforums.com/showthread.php?t=103746&highlight=thrush
This may help, Its for the glasspack mod but should give you an idea of how to do it. Just cut the end with the exhaust tip off and weld it back together after removing the baffle (carefull to align the brackets in the correct place). You can either leave the exhaust pipe stock or cut it and weld a wider diameter like Dustin did
If your friend is ever in the Wichita area, I have a set of debaffled mufflers that were on the bike when I laid her down. The heat shields are fubar but the mufflers are still good. Not asking anything, just want them out of the garage.
1 - 8 of 8 Posts
