1 - 5 of 5 Posts
2013 XCT 4k miles. Everything on bike is working fine other than LCD display and gauges. I checked fuses, connections inside the faring and everything seems to check out. Any thoughts would be greatly appreciated.
Tighten Battery connections with a wrench or socket just to be sure.
ok - did that and still no luck. Cruise control and radio controls are also not working.
... I checked fuses, connections inside the faring and everything seems to check out...
How did you check the connectors? Because this is a connector issue, not fuse. Disconnect the main harness connector in the fairing (the one with the most pins) and reconnect it. Make sure it clicks closed, and then turn the handlebars left and right and make sure they do not tug on it. Test again and see if that fixes it.
Yup - it was the gray connector going into the back of the dash. Pulled apart there put a little dialectic grease on it, plug it back in, and everything is now working! Thanks for the help!!!
1 - 5 of 5 Posts
