1 - 12 of 12 Posts
Question, steel frame and cross and visions have a different teeth counts?
I run a HD belt on my jackpot, but have the stock belt on my CCT
Andre using TaPaTaLk
anyone found an after market supplier for drive belt on cross bikes??
Got this from another site.
I believe I gained the following information:
1.There was one, and only one manufacturer of this particular belt.
2.It is used nowhere else; Victory specific (for aluminum frames).
3.The manufacturer is NOT allowed to make them unless they have a purchase order in hand from Victory; Victory owns the licensing rights to the manufacture of this particular design for the next 10 years.
4.Gates rubber co, at this time, has no purchase order from Victory.
5.As Victory has ceased production, there is no expectation of a purchase order from them.
Chain driven it will be then for my CCT
@BP6666VR , for reference can you let me know specifically what HD belt you are using as well as what drive and rear wheel sprocket on your Jackpot. Or send a link to another thread you posted it in. I haven't been able to come up with it.
Thank you.
As vindex1963 said, there is no substitute for a stock-pullied aluminum frame (Vision, cross bikes). It's 28mm wide by 154T. If you have an underdrive pulley, there are a couple of options: Polaris #3211168, which is an Indian belt, and Harley #40145-07, which is the belt for the international spec V-Rod. Both are 152T. The Indian belt is 24mm and the V-Rod belt is 1".
I haven't actually mounted one of these up, but I did the math and it should put the axle 3/8" - 1/2" forward from the stock location.
Are the tooth sizes the same?
Stock aluminum = 154 tooth
And Stock steel frame = 147 tooth
Aftermarket HD Buell size = 145 tooth for steel frame that fits
Aftermarket HD Vrod size =152 tooth for aluminum frame that fits
See everything comes together, it is like a puzzle... Everybody has a piece to share...
1 - 12 of 12 Posts
