1 - 3 of 3 Posts
Adjusted the slack out of my 2010 Kingpin for the first time and re-aligned the belt by the book but can't seem to get the belt to track properly on the rear sprocket. I've tried and re-tried the alignment and even tried some tips from other posts for the life of me I can't get it to track to the inside of the pulley going forward. Off the ground it come in great but after a few miles on the road it moves from inside to the outside of the pulley. The bike rides fine and have no noticeable belt noise.
Any thoughts??
Yep. You want the belt to track very lightly to the outside not the inside. If it isn't too tight or too loose; you're golden the way it is.
When you spin the wheel, with the back wheel off the ground, backwards; it should slowly walk toward the inside.
Drive BELT Alignment Help
great thanks, I'll check it again, always thought it was suppose to track to the inside or center going forward
1 - 3 of 3 Posts
