1 - 1 of 1 Posts
Hi, i scored a used drivers backrest. Not sure how to install. Has a plate with two nuts on it that I assume goes inside rear fender. These nuts hold two cap screws that go through backrest bracket and rear fender. Back side off bracket has rubber fitted to it so as not to rub fender? It also came with two wuarter sized washers. It looks like they were installed between backrest bracket and fender on the pervious owners bike? Is that how its supposed to be done? Are washers part of the assembly? If this is done in thexsame way as pervious owner the washers will damage paint on fender.
Anyone with proper instruction for victory backrest part number 2875527?
Sent from my SGH-I337M using Tapatalk
1 - 1 of 1 Posts
