1 - 6 of 6 Posts
I have a 2016 Magnum with the Vic LED headlamp. As I get older, the light is not adequate when making left or right turns in the country where there are no street lights. I would like some recommendations for driving lights that can be added to give me more light. Have been looking at the Clearwater Darlas, but they are a bit pricey. Any suggestions?
Thanks! :nerd <<<or should I get these glasses?
I'm using Denali - D2 I got from TwistedThrottle in conjunction with my Vic LED headlight. They are a bit pricey but it comes with a 'plug & play' harness that allows for bright & dim function controlled by the headlights high/low beam toggle switch. I have them mounted on my crash bar and for a small unit they throw a pretty good beam/field of light. They have a pretty good variety of other units as well.
This is not so much a recommendation as to which light to use as advice on how to weed through the gobbledy-gook of LED choices. When researchin' my fork lights I ran into an alphabet-soup of LED descriptions. This site really helped clear the air:
https://nox-lux.com/blog/articles/compare-2d-3d-4d-5d-6d-7d-led-light-bars/
G'Luck, 'n I eventually went with these:
[ame]https://www.amazon.com/gp/product/B07L693XV5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1[/ame]
[ame]https://www.amazon.com/gp/product/B01NAJ2TJD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1[/ame]
Yup, bought both... the 2nd ones lasted the longest.
I use the Show Chrome LED set from Big Bike Parts....these little suckers will light up your world :D and they have been working for years without issue
Just bought a set. Should work well if I can fit them where I want them. Happy to see that visor part is adjustable.
I've had these lights on my 2014 XC since the beginning. I'll warn you they aren't cheap but you'll won't have problems ever seeing the road again with only the bucket light. At a Daytona Bike event a few years ago my bucket LED went out and I was able to drive at night with only the accessory LED lights without any problems. https://www.clearwaterlights.com/products/darla
1 - 6 of 6 Posts
