1 - 20 of 61 Posts
I finally met Kyle at the Southeast Victory Rally and completed 95% of my horse power projects for my bike. He installed the VM1-Touring Cams and throttle ring. He also adjusted the timing gear and idle air valve. What's left? I need to have the ECU reprogrammed.
The two hour ride home was awesome. I had some popping but should be corrected after I adjust the air valve. However, I did see an improve with gas mileage. I average 42.2 mpg going and 45.5 returning even though I was aggressive on the return.
There are two graphs. Graph 2 depicts the results after the bike cooled off therefore showing the air/fuel readings are in-line with each other. Should I go by graph 1 or 2? I would love to say I am 119 hp and 119 ft-lbs.
Regardless, I should be in the 120s with the ECU reprogrammed.
Thanks again Kyle.
Thanks again Kyle.
Were those fuel economy numbers manual calculations or those displayed by the on board computer?
Displayed by the on board computer.
Nice charts.....now....this is probably an example of bad manners, but how much do you have invested to get where you are with those numbers?
The numbers are the numbers are the numbers. The torque is coming on earlier and you bike is making 119hp and T. The only downside is you can't enjoy that power for at least 2 weeks while the reprogramming is being done. Then...you're golden. The bike is running nice. You and Kyle did well. Ride safe.
My dealer tells me about $1800 for:
Lloyds cams
Lloyds Variable Timing Wheel
Power Commander V
Autitune with wide band O2 sensors
I already have the Lloyds air filter and the Tri Oval mufflers. Yes, I'm saving to get these four items done asap.
Discussion Starter #12 (Edited)
No problem. See below:
VM1-Touring cams - $520
Cam Install - $700
Dyno - $250
Air Filter - $135
Idle Air Valve - $77
Throttle Ring - $19.95
Timing Gear - $142
PCV - $369.95
HotVic Debaffled Pipes - $350
119 HP + 119 TQ = $2,563.90
ECU Reprogramming (Not done yet) - $200
120+ HP + 120+ TQ = $2,763.90
Worth it?
No I didn't purchase all at once. Most items sat on the shelf for over 8 months waiting for me to meet Lloyd or Kyle to install.
Discussion Starter #13
Lloyds cams
Power Commander V
I also have the auto-tune but decided not to install after talking to Kyle. It is now for sale.
Cam Install - $700
Dyno - $250
Air Filter - $135
Timing Gear - $142
PCV - $369.95
Worth it?
That actually seems pretty damn reasonable to me!
I was quoted just about 1800.00 from my dealer fro the exact same install VM1 cams, Air filter, timing wheel, PC-V and install. I also got virtually the same price from Lloydz and his price includes dyno tune. Dealer said they could dyno it but it would cost more and that they had had very good luck just getting the settings from Lloyd.
I am going to make the 1000 mile round trip to Lloyd to have him do mine. I am fully confident in my dealer, but why not make a ride ou tof it and let the man himself do the job.
Discussion Starter #16
You can save some money by going with the VM1 cams vs. the VM1-Touring cams. But, less performance.
Very impressive
Nice list of add ons too
Do you notice any added valve noise?
Do you know where Kyle set the timing wheel? I have mine at 5+ and the improvement is dramatic, to say the least.
I talked to Rylan about the difference in the cams and he said that unless I was going to spend my time above 4500 RPM to save my money and go with the original VM cams. He said that made very similar power until above 4500 rpm. While the numbers of the touring cams look good, I believe I will stay with the originals and save a few dollars.
1 - 20 of 61 Posts
