Dynojet Power Commander V (PC5)(19-009) and Dynojet AutoTune (AT-300) for Victory Cross Country Cross Roads (2011-2015)
Brand new in box. Purchased in 2018 but never unwrapped or installed.
Power Commander V 19-009
The Power Commander is a fuel injection adjustment unit that plugs "inline" with the bike’s stock ECU (electronic control unit). The PC uses original equipment style connectors, so no splicing or cutting of the harness is required. Most installations take less than 15 minutes, some as little as 5 minutes.
Changes are made to the bikes fuel and, in some cases, ignition curves via the PC's onboard microprocessor. Using this technology we are able to offer a large area of adjustment without making any permanent changes to the bike’s ECU. Removing the PC returns the bike to its previous stock condition. Each unit comes complete with software and cable link that allows you to change between different maps or make adjustments to a map file.
AutoTune AT-300
Once installed, the AutoTune kit monitors the air/fuel ratio. It then sends this information to the Power Commander V and automatically corrects it as you ride, letting you feel the changes as they happen. Each map that we offer has preset air/fuel ratio target values included that we find to be the best overall settings. This lets you simply plug in the unit and let it do the work.
