1 - 18 of 18 Posts
I was checking rear tire pressure today and noticed this,i don't remember seeing it before, it looks to clean to be a crack, maybe an alignment mark. Since I ride 2 up most of the time I just wanted to be sure.picture posted upside down.... dam..
Wow. I'll have to look at mine when I leave work. That doesn't strike me as normal; I doubt it's an alignment mark, I would expect several alignment marks. I wish the photo was larger so I could zoom in and see more detail.
Thanks for the quick reply. Hope its normal...:eek:
It's an alignment mark. I about freaked the first time I saw it on mine.
I hope so, was taken some twisties pretty fast the other day....:smile
Yep. I take my doubt back, I have it too. Carry on!
Thanks man, just couldn't remember seeing that before..scary lookin tho...cheers
:smile:smile:smile:smile
@Weeds I knew you were alright from the moment I saw that pic. :smile That said, I remember a few years ago there was a member here that had a swingarm failure, where it split through right in front of the adjustment slot :|
Now go have a Mind-Eraser 1 part Kahlua, 1 part Absolute, 2 parts seltzer
Having a beer as we speak...:p
Make it two..and that works ;)
Will do, thanks guys for the fast replies, thumb up do to surgery I haven't been under it in awhile. planning on getting caught up on some riding before winter...:pepper:
Just to be sure I would maybe take a piece of paper or something and make sure the crack dont go all the way thru. Or if you can clean it enough to verify.
Discussion Starter #16
Double checked, looks shallow, and smooth, thanks for the tip...:smile
doesn't that metal plate have a notch or line on the bottom side. ( your photo) what I'm trying to say that plate is up side down. The open slot should be on the bottom
Discussion Starter #18
Hey Johnny, the original pic is upside down, I posted another pic a couple posts down....
1 - 18 of 18 Posts
