1 - 3 of 3 Posts
If I remove the battery cables on my CCT, will I lose the information and the map that Rylan programed in it? I'm not sure if the PCV has an internal battery to maintain its information and/or map if it loses power.
Over the winter I typically like to clean the battery terminals and put a little protectant over them. I may also end up replacing the starter relay with the one from NAPA after I coat it with water proofing just to be on the safe side.
ever since sealed battery's came out our terminals don't get dirty.
Put a star washer 1/4" sizes from hardware on each terminal and they will not come loose. You can even do that on ground cable thats on motor and solenoid. Ground on motor and solenoid use smaller washers
1 - 3 of 3 Posts
