1 - 9 of 9 Posts
Anyone have the specs for the heated seat? How many amps? Does it have a fuse onboard?
There is a 20 amp fuse located between the 40 amp breaker and the chassis relay, which feeds the seat.
Dustin0479
I thought you were the type that would read your owners book and see the information. Guess not
I have the manual but could not for the life of me find it anywhere in there last night. The mechanical side of the manual is killer, the wiring portions suck!
Sent from Motorcycle.com App
The 20A fuse is labeled chassis in the fuse box IIRC. This same fuse will not let the cruise set if blown. It probably has some more functions as well, just not sure what. My seat kept blowing the fuse and I knew it was gone after the cruise cut. It will turn on, red light on the control, but not set. Confusing.
Vic must have done the electrical on a hangover Monday after a 2 week rally and a 96 hour ride back home.
Thanks. I am going to drop a 15 amp fuse on a line I jump off there for the air ride. Working on fabricating some brackets and getting ready to do an install video for a Platinum Air ride on the xc.
1 - 9 of 9 Posts
