Hey guys. Previous owner lowered the bike and had 0 preload on the shock and never had a passenger on the bike. You can guess what happened. Had my girlfriend on the bike and the tire rubbed the wires. Blew the 15A fuse and i took the fender off and fixed it. This happened a second time after adding a bunch of preload. Only this time the left turn signals arent working at all. It flashes on the cluster and thats it. Even with the rear fender plug off the front left turn signal doesnt work. Everything else appears to be working fine.
I did make the mistake of putting a 25A fuse in where it was a 15A because its all i had and i wanted to see if it was working the first time i fixed it, and i forgot about it. So far i've separated all the wires and wrapped them in electrical tape where they were bare. I'm thinking its a ground issue, even though according to the schematic the right turn signals share the same ground. Also, i've checked to make sure the bulbs weren't burnt out. Any help would be appreciated, thanks. cheers
