1 - 6 of 6 Posts
I don't know much about electronics, so please forgive my ignorance.
Vegal Low, 2008 model, 3650 miles on it. Turned the key to the On position, lights went on, fuel pump primed, pressed the start button, it made a noise like an electrical component failed or shorted out.
Now, turn the key to the On position and nothing happens, no lights, no fuel pump priming, nothing.
Checked fuses in the fuse box, all are good. Checked the fuse on the battery cable, it's ok. Battery is charged.
Could it be a relay problem? How do I test a relay?
Any help is much appreciated.
Mark
Remove and clean battery connections. reattach and try again. Also possible bad cell or two in battery.
If nothing comes one at all start with battery then go straight to the 40 amp breaker thats the only thing between battery and fuse box.
1 - 6 of 6 Posts
