1 - 2 of 2 Posts
I have no tail light,multi function read out, or speedo illumination.i've checked EVERYTHING...Wiring ,fuses,cleaned connectors...And no luck .The tail light does work in park mode .
01'V92SC
Light problem
Your park mode, like all the other listed electrical items, is subject to the key switch. Park mode indicates there is power to it so I would begin there with a volt/ohm meter. Not having a schematic to see if all the listed items have a common ground, there is at least one hot wire coming out of the switch for the park light. Does the fuel pump energize the system? You never said if the engine would crank or start.
[email protected]
Retired USN
07 Vegas
Windshield, boards
tach, Mustang seats
50 mpg...really!
1 - 2 of 2 Posts
