Possible diode issue
The local victory mechanic suggested that it very well could be one of the diodes. This seems to make sense we seem to have current flow in a direction that it should not be flowing and the diodes I assume prevent that. He suggested the tall metal fuses in the blocks were the diode but the did not test out to be diodes I think they are just a different kind of fuse. You can see one in the photo it has 15 printed on the top.
From the wiring diagram it appears their are two diode and they are both located in the "auto cancel turn signal module". That is the part I asked about earlier. It sits next to the ignition switch. Wonder how you test that. Something tells me you just replace and hope.
