1 - 7 of 7 Posts
I have a 2006 Vic Kingpin with 40k miles, recently it started missing badly especially at low speeds, ive drained gastank thinking it might be bad gas or water but that wasn’t it, i replaced the injectors, new fuel line, new throttle body adapter that was dry rotted. , new spark plugs, Idles smoothly but as soon as I throttle up it stumbles and acts like it wants to die, doesn’t seem to miss as bad at high rpms. Any ideas?
Have u checked your battery connection to make sure they are tight
Reactions: Jim in Ellijay
Yes it has a brand new battery with good connections
How long after install did it start doing this?
If it's not the battery, and you need to take the terminal wires off, wire brush them clean, then reassemble to be sure you have the good connection it needs, then I would look at the plug wires and plugs. Cheaper to replace the plugs first. I used some Ford Focus wires on my 04 KP and they are still going strong. The key is the ends of the wires have to match your existing wires.
A better option is to simply buy a set from buywitchdoctors.com. I'm kinda cheap so I like to find cheaper alternatives if I can.
Discussion Starter · #5 ·
Yeah the set of oem victory wires $90, its got new plugs, same as original. That was probably going to be my next replacement though.
Check the main circuit breaker located next to the battery.
The previous owner of my bike lived in Arkansas and I think he used to pressure wash the mud off the bike check the pictures and you'll see the corrosion inside the circuit breaker
by the way you can get the exact part from Amazon
I fought this issue for months trying different remedies
Sent from my SM-G960U1 using Tapatalk
That's pretty rusty
1 - 7 of 7 Posts
