1 - 3 of 3 Posts
i found a 2002 engine unit but i have a couple questions. is the flywheel exciter ring the crank trigger wheel? do i replace that with my 99 ring and the sensor that bolts to the case to complete the swap? what about the voltage regulator? do i just use the 99. thank you for your help its been much appreciated
thank you for your help. ill let you know how it turns out. cant wait to ride even though it is cold now
1 - 3 of 3 Posts
