1 - 8 of 8 Posts
I've got a 03 deluxe cruiser i want to swap to a 06 hammer v100 6 speed what problems may arise
The Vic Shop should be able to help. I'm stuck on mine so I'll be calling Rylan this week.
Welcome,
just tryna have a better look at that bike of yours but the avatar pic well , its an avatar pic.
Show us your bike?
Old post I resurrected.
KevinX helped me out. I did a 2012 engine into a 2010 Cross Country. I was told by someone else I needed to swap the ECM from 2012 into the 2010 bike to match the engine. That was incorrect. What I needed to do and therefore did, was swap the transmission indicator sensor from the 2010 into the 2012. All worked well after that. Thanks Kevin!
This is definitely something good.... Kevinx is the master,
So when will you be able to ride the bike?
Andre using TaPaTaLk
From what I understand its not cheap. Unless you are seriously attached to that bike its easier to sell it and buy a 106 model. Rylan has some info on his site blog about that. Looking around $5,000 bucks.
"Since 2003 there has been an update where a 2003 transmission could be retrofitted into a 1999-2002 case. The “kit” was discontinued about 2009, but parts are still available to al-la-carte to convert your old transmission to the newer, better 2003 style. Expect to pay in the area of $4500 parts/labor/tax to do this conversion here at the Vic Shop.
Engine swaps:
The next natural question you’ll have is: can I swap in a later model engine and transmission. Maybe even a 6 speed? The answer is: Yes. The Vic Shop specializes in swapping 2003-2005 92-inch 5-speed engines into the older models. We can also do a 100inch 6-speed conversion for a bit more money. Again, expect to pay in the $4500 parts/labor/tax to have the 92/5 conversion done. Add another $1000 to do the 100/6 combination. Also keep in mind that the donor engines are coming from motorcycle wrecking yards, and finding a suitable donor can sometimes be an issue."
1 - 8 of 8 Posts
