My '09 Jack shivers when the rpms go over 1500. Gets real nasty if I bury the throttle. Put a PCV on it and had it dyno'd, but no diff. Cam chain tensioners? Balancer?
are you feeling the vibration in the front or the rear? Is it excessive in the floorboards?
You're really not telling us much. What have you check and did you just wiggle with your hand or really try to see if its loose?
It's in the engine. Feels like riding on steel wheels, and it thumps at idle too. Over 2000 rpms it feels like the engine is going to jump out of the frame. Something's loose in there.
Check the timing wheel, there were cases of that locking bolt snaped-off or fall out, I cannot remember, that can damage the engine servere due to the chain etc....
So you put a
PVC & Dyno
Throttle body
Touched butterflies valves
Compression test
Timing wheel
Hmmmmmmm seems there is a slight chance there is nothing wrong with your engine.... It MUST be a simple thing that's doing this to your bike.
When I upgraded all my bolts-ons my self for some reason my injector failed on 1 cylinder, it was a sunovabeach to find that, so the engine ran terrible, and I got a low voltage on that injector, etc etc...
So I unplugged it & cleaned it and it was running normal again, took 12 hours to find but the fix was 12 second, hi hi
Most time people overcomplicate the core of the problem, it's easy to get sidetracked , it is easy to think it must be something completely different like a engine problem or worn cam, etc
all I do is trouble shouting on really big jackups, so I listen to all the information they give me, read the 300 emails, and most time I find the problem in a area they never thought off
Hope I did not overflow you or offended you.... please keep us updated , we all want to learn and support our fellow vic riders
Also I like what @visionjohnny said, can you wiggle the engine?
Is the fuel hose connected untill it clicked, undo the 2 sides and click it back, IAV can be blocked? Or kinked IAV hose, etc etc
Going to check the tensioners and TDC to see if one of the chains might have jumped a tooth. Shop that did the dyno suggested that it might need a new balancer, which means a complete teardown. Cheaper to find another engine.
Unfortunately, I've lost my mechanical spirit and my Indy just doesn't care. I have to diagnose it myself or tell him what to check. There are no other Victory experts in this area.
there is a shop that rebuilds injectors. Google it. If injectors were bad you would have one bad plug I think.
I don't know if you said going down the road and you pull in clutch am guessing no vibration.
Have you checked things like swingarm bushings wheel bearing triple tree bearings?
You said you synced the butterflies how did you do that?
Related Threads
Victory Motorcycle Forum
497.1K posts
48.6K members
Since 2007
