1 - 15 of 15 Posts
Recently picked up an 05 Hammer. This is all pretty new to me though I've learned a ton reading these threads. So here's my dilemma... Previous owner took the mufflers off leaving the header pipes. I am hoping I can find something used to replace it. Will any year hammer exhaust work? From what I've read it sounds like it would, just plug the o2 sensor holes if its off a newer bike. Then I read a comment saying that because newer bikes have the 106 motor it might not work. Can someone confirm?
Yes... 2005 and up Hammer is the same.
If you are planning further mods why go for the Hammer exhaust when a nice set of slip-ons are an option? If you have to pay for new stock ones a few more dollars would get something that would better suit any performance upgrades.
You can find stock exhaust dirt cheap on eBay. I poke in there every once in a while to see if I can find performance takeoffs.
It's usually no, or I do, and they want too much.
I would be more interested in an aftermarket setup over a stock one but beggars can't be choosers. I've seen a couple posted on this site which is what prompted me to try to find out what would work. Not sure if slip-ons are an option. The top header pipe has a chrome tip welded to it. Easily cut off I'm sure but whether or not that affects attaching a slip-on I'm not sure. I didn't mention it before figuring I would be removing the whole thing.
I've got complete stage 1's that you can have for $75 plus shipping.
Looking at that pic I'd guess previous owner was running open pipes with chrome car turn-down and the bottom one has fallen off.....
Hopefully the bike has a fuel controller to adding the extra fuel required with open pipes or this bike would have been running seriously lean.
Just my observance.
Discussion Starter #13
Just my observance.
Pretty sure you're spot on with that observance. Doubt there is a fuel controller but I'll check. It would be under the tank?
well mines under the seat, easier to get to to tune but not so easy as behind the sidecover where it'd be easily stolen.
1 - 15 of 15 Posts
