1 - 18 of 18 Posts
2011 XC first time having the pipes off the head and there are no gasket between head and pipe. Anyone else seen this? I bought the bike new and thus is the first time they been off
Sent from my C811 4G using Tapatalk
Correct... Take a flashlight and look again
Smile
Andre
TaPaTaLk
Reactions: Tarzan
Seek and ye shall find.
Do not replace with OEM, buy better, more pliable ones from Witchdoctors or Lloydz.
Same thing on my 13 Vegas, there were none.
I just ordered stock ones coz i had a few times a leak in the aftermarket ones.... See if the stock ones hold better
Andre
TaPaTaLk
I wouldn't be surprised if there the same as what HD uses
Discussion Starter #15
Found them, got them out and going to use stock ones when I do the install. Pulled them off to do the UD pulley. Going to wire in the speedohealer then put the pipes back on. They where really mashed good in the head
Speedohealer ¿ I thought vics and many other brands was a few Kilometers set to high from factory and if you install a UD pulley or a dark side tire then the speedometer sould almost be correct?
Andre
TaPaTaLk
This way I know it is correct
That is true... And if you live in a area where speedtraps are then it is safe... We do not have a single speed camera here
SMILE
Andre
TaPaTaLk
1 - 18 of 18 Posts
