1 - 17 of 17 Posts
If you are looking to put Exhaust tips on your Cross Country that are from a auto part store what is the inlet size need to be to fit correctly?
I know people have done this but I can't find the thread that talks about this.
4.5" diesel truck tips, cut to length
I like them long so I only cut off about and inch.
The "necked down" part slipped snugly over my Big Honkers and you can see how well the 4.5" matches with the stock exhaust cover.
Reactions: tmracing502
Thank you for info
i cut mine to the length i wanted, drilled the holes and spotted nuts inside, they bolted on like stock then.
it will make it a little louder and deeper
This thread has potential....I've been looking for a set of turn down tips, but can't find anything. I kinda like the "Street Sweeper" thing....Anyone do this (or have a suggestion?)
the earlier vics(tc i think) had turn downs i believe. from what i understand they are almost a bolt on deal
where did you find them, i've been to auto zone and advanced auto parts and they don't have any with a 4.5 inlet
if you look at his pics thats what you will find, its not a 4.5" inlet, the body is 4.5, you will have to cut to length
Reactions: DavePA
None of the local auto parts stores carried a large enough exhaust tip.
I just found out Ollie's currently has some for $12 each. You never know what they're gonna have or when they'll have it.
Anyway, I bought mine on Amazon.
[ame]http://www.amazon.com/Spectre-Performance-22421-Stainless-Slant-Cut/dp/B005M1ZCQ4/ref=sr_1_3?s=automotive&ie=UTF8&qid=1439746684&sr=1-3&keywords=4.5+inch+exhaust+tip[/ame]
I just bought mine and they are going to look awesome but I have Hot Vic powercones so they are not going to right yet so I'm on the lookout for some witchdoctors or something that is louder and doesn't have the dome on the end of the exhaust.
you have to cut the inlet end if the tip off of the tip, drill holes in it to bolt to the mufflers, then bolt them on.
Discussion Starter #16
Got the tips installed,look good and they gave the bike one hell of a bark when getting on it.
1 - 17 of 17 Posts
