1 - 20 of 156 Posts
Okay getting this weird feeling.
It feels kinda like my rear is flat or low.
Tire pressure checks out.
Bike seems to ride okay other than this.
Oh and it only seems to be an issue when warm. Going to work this morning I didn't notice it at all but on the return ride definitely felt weird.
I'm confused.
2012 CCT.
I'm confused.
2012 CCT.
What pressure ya got in it?
Jack it up and check wheel for side to side play.
Tire pressure set to what the sticker says. The prior owner did run lower pressure both tires.
I don't feel like I'm out of control it just feels weird. Morning going to work nothing gets great. Afternoon feels like crap when I'm getting closer to home.
I checked shock too that's good on pressure.
I'll have to dig out the jack tomorrow I heard there is a trick to jacking these bikes with that crossover being in the way. I'll have to search on it.
And what does the "sticker say" about the tire pressure? Can you describe the symptoms further? I don't get a good feel for what you are encountering from just the description of "rear is flat or low".
You need to go watch Pauls Videos about jacking the bike. You can jack on the crossover/just in front support..... if you have the right jack. I got the foot pump jack and the scissor jack like Paul showed in the video. A MUST SEE.
I have been trying to connect with the rear wheel too. I think the weird feeling is because its harder to feel the road. The same thoughts have crossed my mind. I checked tire pressure/ Shock pressure NPF. Those that change to the penske rear shock or the Arnott really appreciate the improvement. In fact the more I have learned about the front suspension the more I feel like it should have been better.
As far as comfort, the rear shock does a good enough job for me. Coming from the Buell, the stiction/ stiffness in the front wheel of the Magnum is a let down. I have not calculated the unsprung mass and all that but I guess they had to do something to keep the wheel stuck to the road. My Buell has Performance Machine Alum wheels and the front end is glued to the road and comfortable. Its a night and day diff when hitting a road buckle.
Have you not had a flat rear?
Unstable, weird, squishy, etc.
It's hard to describe just not "normal".
I've been riding back and forth to work for days then suddenly getting this weird not normal feeling. Even at low speed. It's a bit scary.
I was off the road end of last week for rainy weekend checked tire pressure all good there.
Bike will be off road until I figure this out. Sucks since it nice all week.
Only thing I can think of is the increase I made in rear tire pressure but I was just filling to spec on frame. More pressure shouldn't feel squishy though. That was before all that riding to work too. This weird feeling happened after days of normal.
For a start your better off running an extra 4lbs front and rear, bike will love it and tyres will last longer.
Cant see what yr riding cos Im on my phone and sigs dont show.
Maybe get a shop to check it out or get another friend to ride it see what they think.
Yr back wheel not loose?
Jack her up check side to side movement for wheel bearing slop.
Who put yr last rear tyre on, take it back to them and get em to check thier work.
40 psi front, 42 psi rear. 20 psi +/- in rear shock.
What year was your tire made ? Maybe they sold you a 5 year old tire ?
Is your axel nut loose ?
Andre using TaPaTaLk
Discussion Starter #13
Tire was on bike when I bought it in May. The symptoms came along suddenly with me riding almost daily.
Pressure is 40 now it was less. Shock psi good.
I'll get it jacked up and see if something is loose.
So maybe your tire is from 2012 ?
When i bought my second vic, a CCT the tire was 2014, and it was outright dangerous to ride that rubber ... Slidder and slide ... Chucked it in the bin and put some real tires in it ...
Discussion Starter #15
Yeah I guess it could be the tire itself. Going to work about 20 minutes. Going home takes an hour so everything is hot including the rubber.
Just weird that it came on suddenly I think if it was the tire I would have felt it everyday.
Discussion Starter #17
I bet the previous owner ran it low and the tires are cupped.
Would that be more noticable as the tires heat up?
I guess I've never had cupped tires before on my other bikes so I'm not familiar with it.
One description is wobbly and that is pretty accurate to what I'm feeling when it's hot and lower speed.
If the tire is older than 3 years, get rid of it . They can come apart and it is not fun. I found out the hard way, I have had a front tire start losing it's tread at high speeds. Be careful.
Discussion Starter #19
Front is early 2017. The rear is a 2015.
I've never seen a tire come apart but I won't ride when I start seeing age cracks then it's time to go.
2015 should be fine.
But!....previous owner admits to running it low on pressure, why we will never know.
Its worn to a strange profile probs excess wear on outsides as well as cupping.
Now you got proper inflation the tyres not in full contact with road!
Think about it...a good tyre has a contact patch the size of a credit card and yours has a lot less now.
Piss it off and get a new one
Its your life.....
1 - 20 of 156 Posts
