1 - 4 of 4 Posts
Can a FIAMM air horn (similar to a WOLO Bad Boy) be wired using the stock horn wiring or ??
I'm pretty sure there's a reason they come with a relay. I've put two on and always used heavy gauge wire and replaced the cheap relay with what I feel is a more substantial one from the auto parts store, soldered & shrink wrapped everything and never had an issue. You want to blow the horn not your fuse panel.
Yes, however, I thought I read somewhere that still causes a problem ... not sure how it could tho ???
1 - 4 of 4 Posts
