1 - 5 of 5 Posts
well my 2010 vegas with 18k miles has been down a good part of the summer. One day upon starting it just quit fouled plugs then let the fouled plugfest begin. so between every change i made i was getting between 10 and 40 miles before starting again. i was running too rich.1 so i pulled the baffle and cleaned the air cleaner NOPE. 2changed coil pack/plug wires NOPE. 3. Cleaned the throttle body NOPE. 4. Engine light finally came on. took it to the shop had a bunch of ( idle air control circuit out of range) codes upon mechanics recomendation i replaced the Low air cut off valve breather solenoid and the TMAP Sensor NOPE!! 5. then found a thread about re setting the TPS ( throttle position sensor). a 10 second deal. Afterwards i heard some kind of sound that i have never heard before? This appears to have fixed it. i have well over 150 miles on it and seams to be running perfect as before. Sure hope this helps someone due to my struggles. I can post the directions for this if anyone is interested
Absolutely, please post the instructions. I know that I would be interested. This would be applicable to all Victory bikes and not just the steel frame ones, correct?
G'day,
Vinish
all i know is that this worked on my 100 cu "
1. start with key and kill switch off.
2. key to on ( let prime) kill switch on
3. slowly roll throttle from 0% to 100%.
4. Hold throttle wide open for 5 sec.
5. let throttle snap back to 0% as fast as possible
6. turn kill switch off then key off
thats it good luck
This does work for all Vics. It worked on my 99 V92C and it worked on my 07 Jackpot
1 - 5 of 5 Posts
