1 - 6 of 6 Posts
Got my Lindby highway bar in last night. Looked at it last night and thought it would not be too hard to put on. I plan on going for a ride this weekend and I wanted it on before then. Figured I could get it on when I got home from work tonight.
I wake up this morning at about 5:15 and cant go back to sleep, so I got up and did it this morning. Anyway here it is.
Looks good bro, is it easy to install it yourself?
Only problem with the bar is the o-rings will dry out an fall a part. Keep them lubed with something like armorial
Looks good
Trickiest part for me was getting that right side clamp on the frame, working around the heat shield of the front pipe.
Just leave all the bolts a little loose until you get the whole thing on the bike, then snug them down. It helps in lining up the bar across the bottom.
1 - 6 of 6 Posts
