1 - 5 of 5 Posts
Check air pressure in tires. Mine was down 4 pounds from last month and we only had a couple days in the mid 90;s and a few high 80's.
I had 17 thousand on the last set of tires and with the price of tires going up I want to get all the life out of them I can.
If you read this and later this summer put up a post about your tires cupping its your Owen fault I warned you.
Good Riding thumb up
I run tubeless Bridgestone exedra on my ness evil 7 wheels and I loose 3-4 psi every couple of weeks (from both tires) I make sure my tire pressure is always @ 38 front 40 rear. Because anything less my bike rides like crap.
Maybe a bottole of Ride on will fix your slow leaks
1 - 5 of 5 Posts
