1 - 5 of 5 Posts
I'm thinking of going with a set of flush mounted turn signals from a sport bike on my fender, as I'm going with a side mount license plate bracket. Any compelling reasons why not to put something like the picture below on? I figure if they're bright enough for the front they'd be bright enough for the back.
Just remember, before you drill any holes, make sure the new blinkers work correctly. cheers
Add the year and model of your bike(s) to your signature, so we don't have to ask you "what bike's this regarding" each time you post. Here's how to edit your signature: http://www.victoryforums.com/showthread.php?t=3511. ;)
Oh yes, before I drill ANY holes in my expensive fender I will be wiring those lights in place to ensure they work correctly. According to the FSM there seems to be connectors in the lighting, so I should be able to do a nice job.
They would look cleaner. Are they LED? You might need a load equalizer or a couple of resistors, so you're not guaranteed a plug and play system, but should be well worth the trouble. Take before and after pics. cheers thumb up
Yeah, I'll likely need a load equalizer as they are LEDs. I'm considering an Arlen Ness cafe fairing as well, tossing around the idea of mounting a pair on the outer edges of that. .....
1 - 5 of 5 Posts
