broggs , I don't think he is securing it to his gonads .....:grinI think flying a big flag for more than a parade would make for a weird-feeling ride or putting a lot of strain on something that shouldn't have that kind of strain on it...
Too bad. Those would have been some strong nads.broggs , I don't think he is securing it to his gonads .....:grin
Yeah. Big D makes 'em for his hitch set up.
https://www.facebook.com/BigDRacks
You could attach a flag pole holder to a trunk rack or luggage rack. Not something you would want to ride faster than 12 mph with though. A common way of doing this is to use PVC pipe with connectors and pins or bolts to hold them together so they can come apart after the PGR ride (or whatever the Flag ride is for) and go into the trunk or saddlebag. A cover or simply some kind of ties after the flag is rolled around the pole would work too.
What I like about Big D's setup is once the receiver or flag holder is removed; there is no visible sign of the hitch being there.
That's what I was looking for. Didn't know if there was a hitch type setup but this says there is. Is it a standard 1 1/4 hitch or something else? I'll contact the guy direct if I go that route.I can attest, because I have his hitch set up, that it is very high quality work.
If I remember correctly, someone I know did some calculations on PVC and determined they would be fine up to 85mph. But that is new PVC and as it ages it gets brittle so I wouldn't trust it for much over 45mph myself and be prepared to pick your flag up some day when the PVC breaks cause it's bound to happen getting over 45mph.I have a 3 flag setup using PCV pipe that sits in the pax seat and uses the trunk for support. I'll post pictures this weekend. As been said, it is susceptible to cross wind but I have road tested it up to 40 mph.
Good point!I can understand there'd be more resistance, but what about a lot of mountainous terrain? Wouldn't driving up a lot of hills impose the same kind of resistance/load that a flagpole might?
