21 - 27 of 27 Posts
Thanks for the replies. I'm not real sure on the local dealer on parts. What I've read taking the forks apart to change the seals will possibly damage the bushings. I don't thinks the forks are bad but I'd have to get so far then have to wait for parts. I'm new to this if you haven't guessed. So the more I can learn before I get into this I'm sure the better it will go.
When i did my jackpot i had blown seals, so i had to do a rebuild, but if the forks are not leaking then i will do the following,
1. As per video drain oil from top-cap only
2. Fill half oil and pump, and drain again
3. Fill as per speck but measure the mm from top of forks also
4. Install top-cap and RIDE AGAIN
Andre using TaPaTaLk
I need to replace top seals . I dint have money for service manual sa if all oil is drained, how much goes back in?? 02 v92tc
Thanks
Thanks
Service manuals are free, click on this name @BBob and find his signature, it has a link to all the manuals, I printed it in A3 size do I can write stuff in the book and easy reading, let us know if you found your manual
21 - 27 of 27 Posts
