1 - 4 of 4 Posts
no special tool needed. On youtube witchdoctor has a how to video
I've watched and he glosses over how he adds fluid to the forks. If he does it by the book, then he most likely either used some sort of spring compression mechanism and something to draw out the fluid to spec. My guess is that he just wasn't that precise about it. Maybe you don't need to be, but the manual calls out a pretty tight margin of error of +/- 3 cc.
But as far as the seals themselves go, about the only thing you might need is a properly sized piece of PVC to seat the components during the process.
clamp the fork in a vise. On the bottom of the fork is a 6mm allen pull it.
With a socket un screw top nut. Its under pressure and can fly off. So go slow. Once top nut is off let fork drain. In your mode there is just a spring in side. Don't do any thing ells to fork just let it drain. If the seals didn't leak before they should not leak now.
Hard part put spring in and top cap nut just get it started. Now take fork and turn it up side down. Put in 6mm allen and brass washer. Get it tight.
Now turn fork over un do cap nut pour in oil put cap nut on and tighten it.
Just so you know that bushing thats on the bottom of the fork tube takes about a 100 thousand miles to wear out.
1 - 4 of 4 Posts
